Kona 3 Avid MC 6.5. deck configuration
Jo Kreutz
on Feb 11, 2013 at 2:43:54 pm
I installed an AJA Kona 3 card on a clients Avid Workstation (MC 6.5.) and everything seems fine so far: Avid Kona 3 is shown on top of program after opening, I can open the kona - tool out of the application, an even in capture- and digitalcut - tool Kona 3 is shown as an in/out option. I also captured via crash record and everything (video and audio) comes in perfectly
Unfortunately I can´t control the deck because in deck configuration I only read "direct on no port" while in the AJA_Avid Software Bulletin it´s said that the card should be availiable in the deck control as "Aja Kona 3 serial" (instead of the "no port") But as the z400 has no embedded serial port I now wonder how this should work!?
So - what can I do that the Kona 3 is recognised in the Deck Configuration Tool?
Any ideas out there?? Thanks for reading so far and I would highly appreciate any suggestions.
MC 6.5.
Aja Kona 3 / Breakout box
HP Z400
Win 7 Pro 1 Service Pack 1
