FS: AJA Kona LHi
Paul Toth
FS: AJA Kona LHi
on Aug 17, 2012 at 5:08:19 pm
For sale: AJA Kona LHi card with breakout box. This is a great unit and works very well with Adobe as well as Avid, both of which I had this one setup for. I have only used this card/breakout box for a short time.
I bought it new for approx. $1900 USD willing to sell both for $1600 USD + shipping. That's like getting the breakout box for free!
From B&H:
The KONA LHi Capture Card from Aja is designed to bridge the gap between legacy analog devices and the latest products using 3Gbps SDI and HDMI by providing editing, monitoring, and mastering of pro-quality video in a powerful yet affordable system. This unit comes with a breakout cable, and can also be connected to an optional breakout box for rackmount I/O convenience and additional connectivity in the form of BNC digital AES/EBU connectors and RCA monitoring jacks.
KONA LHi uses the Aja Control Panel application to configure various hardware parameters and can also be used to auto-detect input format & frame rate and configure hardware-based up/down/cross-conversions
Use this device to interface with devices such as an HDMI-enabled camera, an HD-SDI VTR connection, and legacy analog video equipment
By way of the card's "Input PassThrough" mode, you can configure it to act as a converter within your computer, allowing you to embed or disembed audio or convert a signal like HDMI to HD-SDI
It features full, 10-bit, broadcast-quality, motion-adaptive SD to HD up-conversion, HD to HD cross-conversion, HD to SD down-conversion, and automatic HD/SD 12-bit component analog output
All of KONA LHi's conversions are hardware-based, therefore they are available all the time, even during ingest or playback
Outputs can be configured independently allowing you to have simultaneous HD and SD output, or two different types of HD (720 or 1080) output at the same time via cross-conversion
The card offers DVCPRO HD hardware acceleration
HDMI v1.3a with Deep Color at 30/36 bits per pixel on input & output is supported
It offers 12-bit HD analog component input & output
The card features 10-bit, hardware-based, real-time up/down/cross-conversions
12-bit SD analog component, composite, or S-Video input & output are available
Dynamic RT hardware acceleration is a standard feature
The card features (2) channels of balanced XLR AES digital audio and (2) channels of balanced XLR analog audio input & output
8-channel SDI embedded audio input & output is included
HD/SD Genlock and RS-422 machine control are standard features
It supports LTC input on the reference input
This solution is compatible with Final Cut, Adobe, Avid and most industry-standard applications
From B&H
The XENA KLHi-Box for LHi Cards from Aja is a 1U rack-mountable breakout box that can be used to house the LHi cards. It features cables that connect the card to the back of the box. This unit features built-in rack ears that allow it to be placed in any standard 19" equipment rack.
This unit is a 1U rack-mountable breakout box that can be used to house the LHi cards
