Kona 3 and After Effects CS5.5
Jef Huey
on Mar 22, 2012 at 6:10:53 pm
We just installed the AJA 10.1 drivers and the CS 5.5.3 plugins on a Win 7 64 bit system. It also runs MC 6.0.1 and the Kona card is happy with that software.
The manual is pretty thin in regards to AE. I am wondering what I can really expect in usability. Right now I have a limited set of use options.
For example, if I take quality down from full to anything else, I do not get realtime playback.
The only Output setting that seems to work in the AJA Preview Settings is Output 8 bit RGBA 4:4:4:4. Anything else is non realtime.
I can not get the Secondary Output to work at all.
Does this sound right or is it pointing to a system problem of some type?
Thanks for any insight.
Jef
Jeff Brown
Re: Kona 3 and After Effects CS5.5
on Mar 26, 2012 at 2:18:07 pm
Jef,
My limited experience w/ AE on a Windows system is that for realtime playback:
1) Do not use autoscale in the Kona output. Make sure it's 1:1, i.e., if you are working at 1/2 rez, then you have a 1/2 size window on your SDI monitor.
2) Match the computer size to the playback size. I don't get realtime if I zoom the computer display to 50% while generating a "full" size preview. Computer display at 100% with full-size preview works well.
And, do make sure you are rendering a preview, not using the space bar.
I'm using the 10.0.1 x64 drivers and the 5.5.2 x64 plugins.
-jeff
Jef Huey
on Apr 28, 2012 at 4:53:26 pm
Sorry for slow response.
Thanks for the suggestions - I will give them a try. Especially the "no autoscale" - I am pretty sure I have that enabled currently.
Sure wish the document was better.
Cheers,
Jef
Jef Huey
on May 4, 2012 at 7:10:43 pm
Hey Jeff (with 2 f's ;) )
The "don't use Auto Resize Image" suggestion was great.
Thanks again!!
Jef (with 1 f)
Jeff Brown
on May 7, 2012 at 12:51:17 pm
From (ff) to (f): glad it helped!
