Kona and Premiere scrubbing problem
Javi Aledo
on Aug 27, 2011 at 7:11:14 pm
Someone using the Kona 3 with Adobe Premiere CS5.0.3 can smoothly scrubbing or it causes delay in updating the image?
Alguien usa la Kona 3 con Adobe Premiere CS5.0.3 puede realizar scrubbing de forma fluida o le produce retraso en actualizar la imagen?
Gracias!
CG, Music, Photography, Programming...
http://www.JaviAledo.com
Peter Gruden
Re: Kona and Premiere scrubbing problem
on Sep 6, 2011 at 8:22:24 am
I have Kona LHi and I see the same slow scrubbing and general less responsive behaviour. This is in Aja sequence preset, when viewing video on a video monitor. It happens either on Mac or Windows.
In Premiere sequence preset, the same video scrubs a lot faster.
I beleive a faster CPU will help.
Peter
Javi Aledo
on Sep 8, 2011 at 7:23:16 am
Hi Peter
Have you tried it in CS5.5?
Cedric Pottier
on Sep 13, 2011 at 2:45:00 pm
I have the same problem with the IO-Express (same spec as LHi) and Premiere CS5.5
I use a i7 980x CPU so this will not be the issue.
This delay when scrubbing makes work very difficult to do.
I hope this will be fixed quickly by AJA.
cheers,
Cedric.
Javi Aledo
on Sep 13, 2011 at 9:12:16 pm
Thank you!
Mikael Bergstrom
on Sep 22, 2011 at 10:20:25 am
The same here to, this is my spec.
Intel i7 950
24 gb of ram
GTX 470
Adaptec 3085 raid card with 4 x 1TB raid 5 (video disk)
SSD Intel 160GB G2 as system disk with Win7 64Bit Ultimate
Adobe CS5.5.1
Regards
Mikael
Mikael Bergstrom
Six String Studio AB
