Kona LSe & Premiere CS5
Andrew Harcourt
on Nov 22, 2010 at 8:56:44 pm
Hi all. Just upgraded to Premiere Pro CS5. Experienced upside down preview same as CS4 and v4 drivers so rolled back to CS3 and all ok. Made the jump to CS5 and still have the same problem with upside down previews. Also when I analog capture I get green flashing all over the image so that it is unwatchable. Any ideas or am I doomed to return to CS3 and v3.5 drivers that work?
Cheers Andrew.
System:
Core i7 CPU
Gigabyte EX58-UD5 Motherboard
6GB RAM
Quadro 580 graphics
Raid 0 stripe media drive
Jeff Brown
Re: Kona LSe & Premiere CS5
on Nov 23, 2010 at 3:09:16 pm
You didn't mention: are you using the 5.0 drivers with CS5?
Andrew Harcourt
on Nov 23, 2010 at 6:23:28 pm
Yes using v5.0 drivers with CS5.
Jeff Brown
on Nov 26, 2010 at 5:17:14 pm
Hmm, well. Perhaps it is related to the prior LHe problem. I have a Xena 2K (now Kona3) that seems to work fine with CS5 & Win7-64.
Try calling AJA directly, they have been helpful to me in the past.
-jeff
Jeff Brown
on Dec 10, 2010 at 9:21:25 pm
Update: I loaded in some DSLR footage from a client, and it was previewed in Premiere upside down!
Fortunately, I do mostly visual FX/animation, so everything gets converted to file sequences as step 1. I can confirm the issue, though!
-jeff
