LHi field preview in AE
Tim Stonesifer
on Oct 22, 2009 at 5:41:20 pm
I'm new to the LHi board, so this is probably a simple interface question, or just a limitation of the board I'm not aware of: When I do a preview in After Effects, is it possible to get it to do a field render? I see this option in Premiere, but not in AE...
Mikael B
Re: LHi field preview in AE
on Oct 24, 2009 at 9:57:44 pm
Take a look at this video:
http://www.aja.com/products/xena/ajaxOverFlow.php?keepThis=true&TB_iframe=t...
Mikael
Grammofonbolaget
Tim Stonesifer
on Oct 26, 2009 at 9:32:14 pm
Thanks Mikael, but the video didn't really seem to answer my question. Do you know of a solution to the field order preview in After Effects?
Jeff Kosmicki
on Oct 28, 2009 at 1:33:21 pm
AE works completely in full/progressive frame, so when you do a RAM preview you will not get interlaced fields. When working with interlaced footage, you need to separate the fields for each clip using the interpret footage settings. You can then set AE to render fields in the render settings.
Jeff Kosmicki
http://www.toyraygun.net
