Xena LHe not seeing decks in Premiere or Machina?
Joe Gill
on Oct 22, 2008 at 10:48:32 pm
I am using these for ingest for compression - they worked fine for a while and the operators have updated to 3.5 drivers, and now the machines seem to be unable to control the decks using the regular 422 cables.
I have uninstalled, gone back to 3.0.1 and come back to 3.5, run new test cables which also didn;t work, but tested all the cables with a DNF controller box, and now am stymied. Anybody got any thoughts?
Joe
Joe Gill
Joe Gill
Re: Xena LHe not seeing decks in Premiere or Machina?
on Oct 22, 2008 at 11:43:57 pm
So I have removed the software using the uninstall as well as the remove, pulled the card and rebooted clean. I re-inserted the card in the machine (HP) and re-installed everything, and still no deck control...
Joe Gill
Tim Kolb
on Oct 27, 2008 at 1:28:43 pm
Can you see that RS422 deck remote is selected in Premiere Pro and Machina?
This sounds like a software setting might have gotten flipped someplace perhaps...?
TimK,
Director, Consultant
Kolb Productions,
CPO, Digieffects
Joe Gill
on Oct 27, 2008 at 5:48:19 pm
Restored system to working point, and still the 422 is unresponsive... Checked all the settings...
Joe Gill
Tim Kolb
on Oct 27, 2008 at 7:34:11 pm
Does Machina see the TC if you just manually press play? What format are you using and how is it coming in? (SDI/analog, etc...)
TimK,
Kolb Productions,
CPO, Digieffects
