Enabling live output from Premier CS3
Maxwell Federman
on Sep 4, 2008 at 4:27:29 pm
Hello
I recently visited a colleague who is using Media100HD which incorporates an AJA(Kona) card, and allows him to output multiple streams of HD or SD video, each one with independently selectable output resolution and aspect settings.
I have an AJA Xena card and run Premier Pro CS3. I have used the Machina App to capture, and then imported the files into Premier.
What do I need to do (settings, software updates, etc.) in order to use the card to output video and capture directly into Premier??
Thanks for taking the time to read this post...
I appreciate your assistance!
Max Federman
Tim Kolb
Re: Enabling live output from Premier CS3
on Sep 9, 2008 at 2:19:59 pm
just take the M100 HD and output HD via SDI and cable it to the Xena card and capture it as HDSDI...
It should be pretty straightforward actually. It would probably help to feed them both the same blackburst/sync signal so they sync up nicely...
TimK,
Director, Consultant
Kolb Productions,
CPO, Digieffects
