Aja XENA LHe downconvert looks bad?
maarek
on Jan 31, 2008 at 10:41:17 am
Hi all!
My Aja XENA LHe downconvert (from 1440x1080 dvcpro hd to sd resolution looks horrible. There are loads of jagged edges and it looks like its 320x240 or something. Is this normal? Regular sd playback without any conversions look great. I'm using a macpro with fcp and all my settings should be ok.
Thanks for any suggestions.
Mikko Löppönen
Re: Aja XENA LHe downconvert looks bad?
on Jan 31, 2008 at 10:45:25 am
And everything has been solved, I had my settings screwed up and FCP was doing the scaling, not AJA. Thanks all :)
Jeron Coolman
on Feb 1, 2008 at 10:13:03 pm
You are using a Xena on a Macpro with FCP? I thought Macs used a Kona... but then again I guess I never thought of which card a MacIntel would use, a Kona or a Xena.
