A whole bunch of Xena LH Questions
Marcus Ionis
on Oct 18, 2007 at 7:55:34 pm
We
szumlins
Re: A whole bunch of Xena LH Questions
on Oct 22, 2007 at 4:21:46 pm
[Marcus Ionis] "1) Does the Xena LH or LHe support the HP8200?
If so any major pitfalls?
Yup. Make sure your storage is on the opposite bus (PCIe for Xena LH, PCI-X for LHe)
[Marcus Ionis]
2) Does the Xena LH capture real-time TGA, TIFF, Cineon, BMP image sequences.
Yup
[Marcus Ionis]
3) Does it output image sequences in real-time to tape?
Yup
[Marcus Ionis]
4) Does the Xena card capture AVI dv/dvcpro in real-time via SDI/HD-SDI
Not currently. Only uncompressed options are supported for capture. All of those options are available for realtime output though.
[Marcus Ionis]
5) Does the card output HDV via SD/HD-SDI? Like the KONA2/3 card.
Yup!
[Marcus Ionis]
6) Like the KONA 2/3 cards, does the Xena LH perform aspect ratio conversions in SD mode? I.e. 4x3 Anamorphic to 4x3 Letterbox 1.78
Only the Xena2K does SD to SD, not the LH/LHe
[Marcus Ionis]
7) Does the Xena LH card perform upconvertions?
No, but the Xena 2K card does.
[Marcus Ionis]
8) Does the card perform a standard 2:3 cadence from SD 24 frames sequence to SD 29.97 tape?
To my knowledge the Xena LHe will do the reverse pulldown for 24p footage.
[Marcus Ionis]
9) Does the card support PAL for SD & HD?
Yup
[Marcus Ionis]
10) Does the Xena drivers read the 8/10 bit Uncompress SD/HD QT from Final Cut Pro?
Yup
[Marcus Ionis]
11) Does the Xena drivers read SD QT using the Blackmagic codec?
Honestly, I'm not sure.
[Marcus Ionis]
12) Does the Xena card need house REF or is there a "Free Run" feature like the KONA2/3 card.
It has both freerun and ref, so either or
[Marcus Ionis]
13) Does the Xena card have drivers working w/Photoshop? The objective is directly capturing screen grabs using Photoshop.
Yup.
Marcus Ionis
on Nov 6, 2007 at 1:14:48 am
Thank for answering my questions.
Really appreciate it
Marcus
