XENA 2K PREMIERE CS2
elmyr
on Aug 30, 2007 at 12:04:45 pm
I've just installed the ver 3.00 drivers and timecode / deck control has died. Unistalled and reinstalled 2.6 drivers and they don't work anymore either.
Sony A500 deck through RS422 - using Insert Edit - deck gets to TC in point and doesn't record.
Print to Video - just seems to create an arbitrary TC point to start recording.
Also - going from capture to export to Tape - Premiere STILL crashes (which I thought was solved in this version)
I'm stuck can anyone help?
e
elmyr
Re: XENA 2K PREMIERE CS2
on Aug 30, 2007 at 1:04:11 pm
More detail:
When using 'Export to Tape' in Insert Edit or Print to Video mode, the 'Duration' figure to the right of the panel always displays 1 frame (00:00:00:01). Regardless of length of timeline.
Hence nothing going to tape.
This is really causing me problems.
e
Tim Kolb
on Sep 5, 2007 at 11:15:13 am
What exactly was the procedure you used for first the upgrade, then the revert back to the old drivers...?
TimK,
Director,
Kolb Productions,
Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net
