XENA batch capture timecode arror
elmyr
on May 26, 2007 at 8:20:13 am
I'm trying to batch capture (Xena - Premiere Pro / A500 DigiBeta) from an Avid Adrenaline edl and the timecodes are out by 2 seconds or so. All clips are coming in 2 seconds early. Now I know I can offset the timcode, but what's the reason this is happening anyway?
Also if I go into capture setting the Aspect Ratio (Primary Format) is locked on 1920x1080 even though I set the the project up in SD. I can't change this for some reason. Again, anyone experiecing anything similar?
thanks
e
