Aja and the nvidia chipsets?
vealti
on Apr 30, 2007 at 9:25:31 pm
Does anyone know if the Xena boards are compatible with the new Nvidia nForce 600 series motherboards?
szumlins
Re: Aja and the nvidia chipsets?
on May 1, 2007 at 3:26:41 am
This might help out a little when looking to build a system:
http://www.aja.com/html/support_xena_rec_sys.htm
-Mike
vealti
on May 2, 2007 at 3:47:36 am
Thanks. I was looking for something like this and couldn't find it. I saw all the boards listed are dual AMD/Xeons. Is anyone using a Core 2 Duo board?
Kevin Christopher
on May 2, 2007 at 6:05:48 pm
Probably not. You really need a workstation class motherboard for uncompressed HD. All of the Xeon boards/systems listed are dualcore/quadcore Xeons. Plenty of speed there. The real test is in the chipset/bus architecture. That is where you will find the workstation boards more stable and better for handling Uncompressed HD.
Kevin
vealti
on May 2, 2007 at 10:54:36 pm
So it's more of a speed issue rather than a compatability issue? I would be using the Cineform codec and using the Xena for capture/monitoring/output. Not even close to the horsepower needed for uncompressed.
R.Howard
on May 7, 2007 at 3:19:28 pm
Kevin,
Actual both server and workstation boards work for uncompressed HD. There really isn't much going on with the procs, given your using the right I/O card for the job :)
We have used a mixture of both and on both Intel and AMD over the years.
Cheers,
Ramona
Ramona Howard
SpectSoft, LLC
593 Hi-Tech Parkway Suite B
Oakdale, CA 95361
Phone: 209.847.7812 extension 104
Fax: 209.847.7859
http://www.spectsoft.com
RaveHD - Changing the way you think about HD
vealti
on May 8, 2007 at 2:03:22 pm
Thanks for all the replys. A Core 2 Duo board fits in my budget for my startup system so I'll try that first with my setup and see how the card works and post the results.
