AVI Capture - Video PLUS Audio in future?
Ben Cheng
on Nov 6, 2006 at 7:51:34 am
Hi All,
I like to find out if its possible to capture in AVI, with both video & audio in the same file, in the future?
Working in Machina or Premiere Pro 2.0.
May I know if there's a workaround solution, if I need the seperate video & audio files, combined into 1 single file?
Cheers,
Ben Cheng
The Media Village
Singapore
AJA Xena Support
Re: AVI Capture - Video PLUS Audio in future?
on Nov 6, 2006 at 6:34:58 pm
Ben,
We are not going to be supporting audio + video in the same file for any file type other than Quicktime.
The only workaround would be to use Quicktime files if audio+video in one file is a requirement of yours.
AJA Xena Support
Ben Cheng
on Nov 7, 2006 at 5:43:44 pm
Thanks for your reply.
Does anyone know of any utility which will combine the AVI video & WAV audio files into 1 AVI file?
Cheers
Ben Cheng
The Media Village
Singapore
Kevin Christopher
on Dec 1, 2006 at 4:54:10 am
There are a couple of ways that come to mind.
First use a program called virtual Dub. It will do it, and it is one of my goto tools in my box for doing all kinds of things.
Second use a simple multiplex program like AVI Mux.
http://www.divx-digest.com/software/avimux.html
Use any at your own risk. Virtual Dub is by far the best, and AVI Mux is the simpleist
Kevin
Ben Cheng
on Dec 5, 2006 at 8:16:03 am
Hi Kevin,
Thanks for your advice.
We gave up the idea of using Premiere Pro as a capture station, as it does not fit into the workflow well.
Cheers,
Ben
