AJA Device for 480i signal to HD 480p/1080i Monitor
Kevin Reynolds
on Nov 28, 2013 at 9:48:20 am
I have a HD (CRT) Broadcast Monitor. I need a AJA device that can take a 4x3 composite signal (480i like out of a Digibeta or SP Deck) and send it to the HD Broadcast monitor as either 1080i or 480p, but it has to go with Black Bars on the left and right so that it stays 4x3 within the 16x9 monitor.
Does anyone know of a device? Make sure it can add black bars so the picture stays 4x3 in the monitor.
Shane Ross
Re: AJA Device for 480i signal to HD 480p/1080i Monitor
on Nov 30, 2013 at 12:24:32 am
YOu'll need a mini converter, like this:
http://www.aja.com/en/products/mini-converters/udc
But call AJA direct to ask what they recommend. But you are looking for a converter, not an IO from the computer.
Shane
Little Frog Post
Gunter Hemeleers
on Dec 6, 2013 at 8:35:29 am
Actually he needs a V2digital and a UDC.
Or an FS1 will do as well but that could be a little bit of overkill.
