io XT/FCP 7/Mavericks? Anybody try?
Christopher S. Johnson
on Oct 22, 2013 at 9:24:16 pm
AJA iO XT, Final Cut Pro 7 (seven), and Mavericks.
I would love to hear if anybody tries this combo. Yes, I understand it's early and risky and AJA has announced nothing. This does not curb curiosity.
Any reports would be illuminating.
-Christopher
Gary Rush
Re: io XT/FCP 7/Mavericks? Anybody try?
on Oct 23, 2013 at 4:37:20 am
Updating now, will respond results
Gary Rush
Gary Rush
on Oct 23, 2013 at 1:06:51 pm
No issues
Gary Rush
Brent Chaney
on Oct 23, 2013 at 2:07:22 pm
@garyRush, So final cut pro 7 worked for you with no issues?
Brent Chaney
on Oct 23, 2013 at 2:27:06 pm
@garyRush, So final cut pro 7 worked for you with no issues? i am wanting to upgrade but I'm scared of losing access to some important projects in pro 7
on Oct 23, 2013 at 4:06:26 pm
Hi Gary, and did you get a steady non-stuttery signal out of the ioXT? Did you open a largish ProRes HD project? Or did you only do an app opening test? Thanks for your input.
Gary Rush
on Oct 24, 2013 at 12:24:13 am
I opened FCP 7 as a test but I'm test avchd files tonight to make sure they transcode and play back okay.
Gary Rush
on Oct 24, 2013 at 12:59:41 am
Thanks Gary. You're awesome. And what about your AJA hardware? In and out?
Gary Rush
on Oct 24, 2013 at 1:11:07 am
Chris, we uses SDHC cams to we just transfer files to hard drive then file- import into FCP7 then transcode to pro res 422
Gary Rush
on Oct 24, 2013 at 8:18:07 pm
Ah, OK. I thought you were also running an ioXT. Thanks.
wolfgang schabhuettl
on Oct 25, 2013 at 8:56:46 am
new mavericks driver released
on Oct 25, 2013 at 2:03:46 pm
THANK YOU, AJA!
on Nov 8, 2013 at 3:38:26 pm
new version 10.4.9 - help for audiosync problems with FCP7
Lip sync fixed
on Nov 25, 2013 at 9:32:28 pm
Some have wanted to know. It took a couple of tries at driver updates from AJA, but I can finally say that Final Cut Pro 7, on Mavericks (Mac OS X 10.9), with an AJA capture & monitoring card (io XT for me) for feeding your client monitor, is feeling reliable after testing. There were some crazy lip sync issues at first, but the new drivers from AJA (10.4.9) fixed it. So like the famous Monty Python line goes, “not dead yet!”
-Christopher
Daniel Frome
on Nov 13, 2013 at 5:24:20 pm
I'm running an AJA T-Tap, which should basically perform the same as your ioXT.
Mavericks support is not as good as 10.8 right now. Premiere Pro and FCP7 both have occasional audio sync and drop-out issues. I spoke to AJA and they are aware of the issue.
on Nov 25, 2013 at 9:33:21 pm
Try 10.4.9 drivers now. I believe it is fixed!
Daniel Frome
on Nov 26, 2013 at 10:02:36 am
It is better, but still not as solid as 10.8. Much improved though.
I've reverted back to OSX 10.8 in the meantime though, because AJA still hasn't released openIO drivers for Avid, and that's crucial for me.
steve knattress
on Dec 27, 2013 at 9:51:01 am
Aja io tx any idea of when io drivers for avid mc7.03 and mavericks will be available?
Anyone using the new avid with aja? What problems do you have?
Is it useable?
Steve
