AJA T-Tap for monitoring
Sascha Engel
on Jun 15, 2013 at 6:50:00 pm
Hallo everybody,
I hope you can answer me this question quickly, since I have to give answer soon.
I have an option to get a T-Tap, and I would like to know, if I have to connect it to a high end HD Broadcast Monitor for doing CC and grading, or if it will be also quiet adequate if I connect to a good screen, such as a Dell Ultra Sharp with IPS?
I have also an older SD Broadcast Monitor - will that help with Grading HD footage, when connected over the T-Tap?
Greetings,
Sascha.
Shane Ross
Re: AJA T-Tap for monitoring
on Jun 18, 2013 at 9:55:01 pm
You can connect SDI to the SD monitor, and HDMI to the Dell. Use that as a BROADCAST monitor? I wouldn't trust it...even if you used a screen calibrator. Well, it might be close. Depends on how close you can calibrate it to bars.
But no, using an SD monitor for grading HD is not a good idea. Completely different color space (Rec 609 vs Rec 709)...and black levels are different.
Shane
Little Frog Post
