Macbook Pro > AJA IO XT > Matrox DualHead2Go
Zac Grant
on May 7, 2013 at 1:16:33 am
Hi Folks,
I've been researching this for sometime and I'm not sure if anyone has tried this set-up and whether it will work?
I'm running a 2012 non-retina macbook pro with Avid Media Composer 6.5 and was hoping to use thunderbolt to connect to an AJA IO XT.
From the IO XT I was hoping to feed two monitors and an LCD/HDTV client monitor.
Macbook Pro > IO XT
IO XT > Mini-display port/Display port > DualHead2GO DP Edition > 2 x Dell U2410
IO XT > HDMI > LCD/HDTV
At a later stage I will probably add a thunderbolt storage device in the chain if it works?
Has anyone tried this/currently using this set-up?
Any advice gratefully received!
