IO XT noisy
Anhtu Vu
IO XT noisy
on Apr 22, 2013 at 11:24:40 pm
I'm on my third IO XT replacement...still the same problem, these things are annoyingly noisy. Is this normal ???
gary adcock
Re: IO XT noisy
on Apr 24, 2013 at 1:50:36 pm
[Anhtu Vu] "I'm on my third IO XT replacement...still the same problem, these things are annoyingly noisy. Is this normal ???"
What are you doing that the fan runs all the time? I do not find the ioXT noisy at all, used in a variety of situations without issue.
Dont cover it up or put drives on it both of those things will cause the unit to run hot.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
Follow my blog at http://www.garyadcock.com
Or follow me on Twitter
@garyadcock
Anhtu Vu
Re: IO XT noisy
on Apr 25, 2013 at 11:47:15 pm
Well i guess it's all relative what one considers noisy. I have it in my PT HD mixing suite, it's simply sitting on a table with nothing around/on top/underneath it. I and all the mixers find it loud as hell. You can really hear the difference when it's plugged in or not. We tried both revision of the IO XT and it does not seem to make a big difference.
Shane Ross
Re: IO XT noisy
on Apr 26, 2013 at 5:16:05 pm
I notice the fans...but I don't think it's LOUD. But then again, you are concentrating on audio, so it is more present in your mind.
Put it under and behind the desk?
Shane
Little Frog Post
