Aja System tests fails on testing FW800-disk
Niklas Wikman
on Oct 10, 2012 at 3:18:50 pm
I've just bought a RAID1 enclosure (Raidon GR3630-WSB3)
The drive is formatted with HFS+ non-journaled.
Before starting using it as a scratch disk for Final Cut Pro, I wanted to run some AJA system test to compare speed with our other scratch disks.
But I get no readings? The System Test does place zero byte files on the disk. But no figures over read/write speed is given.
The disk seems to be just fine in Finder, checking with both Disk Utility, Drive Genius 3 and Disk Warrior.
What might be wrong?
If I try a OWC enclosure with a 2,5" 1TB disk, AJA System Test works just fine.
Does it matter if I connect over FW or USB? I figure the speed would differ, but sure enough the measurement should work regardless how the disk is connected to my iMac.
Testing another 2,5" disk with an OWC enclosure
