Green Horizontal Lines in Capture (AJA Io XT & HD10AVA)
Thomas Frank
on Jun 28, 2012 at 9:35:50 pm
I start to digitize some old VHS tapes with a Multisystem VCR, AJA io XT and a AJA HD10AVA.
The issue I am having that I get green horizontal lines across the frame sporadically or constantly just depends on the tape.
Now it is not the VCR since I have tried three different makes and models. What could and why is this being caused?
Thank you!
David Eaks
Re: Green Horizontal Lines in Capture (AJA Io XT & HD10AVA)
on Jun 28, 2012 at 11:57:14 pm
I'm not familiar with the HD10ava but do you have the dip switches in the correct positions for what your doing? I'm guessing that you have some setting off some where, what are your capture settings? What app are you capturing in? Are you up scaling on input? How are you monitoring?
gary adcock
on Jun 29, 2012 at 12:31:51 am
[Thomas Frank] "Now it is not the VCR since I have tried three different makes and models"
Horizontal green stripes can mean any thing from a failure to a sync issue.
Please post a picture here and make sure that you have it when you contact Aja Tech support tomorrow.
They will be able to help you with both items to debug your issues.
& It might be the tape, can't rule anything out.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
follow me on Twitter
@garyadcock
AJA Sales Department
on Jun 29, 2012 at 4:48:16 pm
VHS consumer VTRs will typically require the use of a time base corrector to produce a stable output signal that can be fed to non-linear editors and professional hardware. In all likelihood, the cause of the issue in this case is the video output of the VTR without a timebase corrector in the signal path. Please feel free to contact AJA Technical Support if you have additional questions about your configuration and the use of the AJA products.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
