AJA I/O Express with Avid media composer 6 and After Effects CS6
Dimitrios Karagiorgas
on Jun 7, 2012 at 12:46:22 pm
Hello Folks,
I'm currently running AJA I/O Express with Avid media composer 6 and want to install the plugin to support AE CS6. Is it possible to run I/O Express w/both? I understand you probably can't do it simultaneously but can it be done for both apps?
The system is a Win7 machine w/lots of horsepower underneath i.e. I7 Quad, Quadro, DDR3 etc.
Thanks for your time,
D
Jonathan Cordell
Re: AJA I/O Express with Avid media composer 6 and After Effects CS6
on Oct 18, 2012 at 2:36:06 am
Yes you can. I called AJA about the same question. You have to install a driver for each in a certain sequence. I'd call tech support and they can help you out based on your current system. I will say though that sometimes mine acts finicky on occasion when having both of them open.
