AJA IO hd audio/video out of sync on output and input
Pat Baril
on Feb 11, 2012 at 1:03:33 pm
Hello,
We bought an AJA IO hd a while ago but never used it untill yesterday. We are in FCP 7, and the sequence is playing in sync through the IO hd sdi out on the monitor. But when we output the HCAM, the tape is at least 2 frames out of sync. We are using the latest driver and firmware for the AJA. We tried on both Snow and Lion OS. Same results. And when we reinput the tape, it is even more out of sync.
The audio delay setting in the AJA control panel are not working ( or at least they don't seems to do any difference ).
We know it is not the deck because we can output/input fine with our other cards ( LHI, BlackMagic ).
I mean, this is suppose to be a straight forward procedure, but it does not work...
Anybody else have seen this? I think I will downgrade the driver to see...
Thank you!
PAT
AJA Sales Department
Re: AJA IO hd audio/video out of sync on output and input
on Feb 13, 2012 at 6:28:13 pm
Please consider contacting AJA Technical Support, if you have not already, for assistance. This behavior sounds out of the norm to be sure. You may reach AJA Technical Support via phone or email between 9am and 5pm PST, Monday through Friday.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
Pat Baril
on Feb 14, 2012 at 2:04:38 pm
Hello, we finally discover that the problem was cause by the AJA driver 9.1. We tried on 2 different machine ( one 10.6.8 and one 10.7.2 ), both running FCP7. We also tried two different decks ( HDCAM and HDCAM SR ), both machine are offsync by 2 frames on input and on output.
Both when we downgraded the AJA driver to 9.05, everything is back to normal, no offsync. This is confirmed on 2 different machines with 2 different OS and 2 different deck.
Can you confirmed that on your side? Has this been tested prior of the release??
Thank you!
PAT
on Feb 14, 2012 at 2:21:02 pm
Please contact AJA Technical Support via phone or email to review your configuration.
AJA Video Systems
(800) 251-4224 US
sales@aja.com
