AJA IO Express Downconverted output (anamorphic) with DVCProHD footage
Trevor Asquerthian
on Feb 19, 2011 at 10:37:46 am
I'm using an AJA IO Express, with v8.1.1 drivers.
Editing with FCP using DVCProHD footage (1440x1080) @50i
Primary output is 1080i via HDMI
Secondary output is SD downconvert via SDI to an SD monitor.
This downconverted output is the wrong shape if set to 'anamorphic' and setting the Sony monitor to 16:9 (i.e. a circle wipe is not round).
It is correct if set to 'letterbox' and leaving the Sony monitor at 4:3.
I assume this is an error coming from the thin raster nature of the DVCProHD codec - the maths in the downconversion being incorrect?
Trevor Asquerthian
Re: AJA IO Express Downconverted output (anamorphic) with DVCProHD footage
on Mar 22, 2011 at 8:20:05 am
On further reflection, it seems to be a problem between keyboard and chair.
