:: AJA io connect to TV LOGIC , monitor::
Martha Poly R. Mendivil
on Jan 28, 2011 at 6:26:09 pm
Hello!
WE're trying to connect a FCP project to display on a TV Logic Monitor through an AJA io using SDI output and SDI input on the Tv Logic. We've been switching around the settings in order to get the image displayed correctly in our Tv Logic. The timeline settings are AppleProRes 4444 1920x1080 running at 23.98fps.
Even if we try different settings of video playback we get the same interlaced image on the TV Logic which doesn't match the look of the project's image.
Any ideas?
Martha Poly R, Mendivil
PostProduction Assistant
El Barandal PostProduction
Mexico City
Jeremy Garchow
Re: :: AJA io connect to TV LOGIC , monitor::
on Jan 28, 2011 at 10:38:29 pm
The original AJA io is SD only.
The ioHD does not do ProRes 4444.
You will need a Kona card for this, or work in a ProRes422 timeline.
Jeremy
