how to use io HD to capture time lapse?
joe mcneilly
on Nov 10, 2010 at 4:41:56 pm
I see tons of artilces and posts touting this feature, but nothing on how to actually do it. I assume it has to go through a Final Cut log-and-capture? Can anyone point me at some instructions on how to set it up?
AJA Sales Department
Re: how to use io HD to capture time lapse?
on Nov 10, 2010 at 9:09:11 pm
Joe,
From pg. 57 of the Io HD 8.0 manual, "Timelapse Tab Screen":
To use the timelapse capability, choose the "Enable Timelapse Capture" checkbox. This functionality is enabled for all QuickTime capture applications (Final Cut Pro, VTR Xchange, etc.) Set the "Capture" and "For Interval" parameters as desired. Launch a capture application like Final Cut Pro, select the desired Easy Setup for the video format desired. You will not need to change anything within the application; the timelapse feature will produce QuickTime files with the framerate specified by the Easy Setup used. The resulting timelapse clip can be used without additional rendering.
On page 58, a screengrab showing the timelapse enabled is also featured.
If you have further questions, you can feel free to contact AJA Technical Support.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
