Resolution Issues over the AJA ioHD
Andree Franks
on Oct 24, 2010 at 4:10:28 pm
Not sure what this will cause it since it just appeared one day, but maybe somebody already had this issue and found a fix!
The problem is when a tape is captured over the AJA ioHD with the Panasonic AJ-HD1400 the footage or clips have a black boarder around the footage.
When imported into Final Cut the black is transparent.
No matter if we use AJA IoHD 525 29.97 ProRes 422 or the standard DV NTSC format.
AJA Sales Department
Re: solution Issues over the AJA ioHD
on Oct 25, 2010 at 7:27:57 pm
Andree,
I would recommend that you contact AJA technical support for assistance. You mention using the Panasonic AJ-HD1400 VTR which is an HD device that could be configured to output SD, so perhaps it\'s a simply a setting on the VTR that needs to be addressed.
Again, please feel free to contact AJA technical support for assistance.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
