FCP - AJ IO HD - AJ-HD1400p - Tri-Level Sync Generator
Eric Beaudry
on May 20, 2010 at 6:05:48 pm
Trying to figure out the proper workflow to edit to tape from FCP using an AJA IO HD and an AJ-HD1400p deck.
Format is 720p 59.94
Need a simple answer. Is a tri-level sync generator (like a Gen-10) needed? Yes or no.
If not, what is the proper workflow (deck settings, connections, etc.)
Thanks.
Bonus Question:
Would something like a gen-10 possibly help with tape trouble issues during capture?
Go slow to hurry up.
Jeremy Garchow
Re: FCP - AJ IO HD - AJ-HD1400p - Tri-Level Sync Generator
on May 20, 2010 at 8:46:34 pm
You can use regular bi level sync for 720p60 (as it's 60hz).
For capture, the AJA products reference incoming video so the sync gen is not needed.
