Betacam SX Capture question
Cornelius Greenway
on May 13, 2010 at 2:22:52 pm
I have a Betacam SX (DNW-A25)with SDI out. I send the signal to a Laird LTM DV Beta SDI to firewire converter.
In fcp I am using firewire PAL 48 khz as capture. Once in the system I notice there is what seems to be noise or some sort of artifact tha was not on the tape.
Once the video is sent out back to tape the noise remains.
Can some one tell me is this is the right setting for capture? and what should I be doing wrong?
Jeremy Garchow
Re: Betacam SX Capture question
on May 13, 2010 at 5:29:42 pm
Do you have an AJA io or ioHD?
Cornelius Greenway
on May 13, 2010 at 10:57:27 pm
Thanks for your response. No I dont I have a Laird BetaDV converter.
Jeremy Garchow
on May 14, 2010 at 1:10:52 am
Perhaps you'll have better luck in a different forum? This is an AJA forum.
Perhaps try the FCP forum here on the cow.
