Configuraciñon AJA Io HD and Final Cut 6.0.6.
Esteban Aguilar
on Mar 16, 2010 at 7:16:34 pm
Good,
I have a problem, We have a MAC Pro and just pass it from tiger to leopard, But when making this change, Unconfiguring the AJA Io HD, Then when working in Final Cut 6.0.6, We can not see the image on the external monitors and when does one see the monitors in audio lags the video. We have tried to configure Final Cut from the easy setup (settings) and settings of the sequence, However has not worked. Both the video and audio are from the AJA.
What happens?
Michael Sacci
Re: Configuraciñon AJA Io HD and Final Cut 6.0.6.
on Mar 17, 2010 at 5:35:41 am
When you do a system upgrade, it should be on a clean HD, so you would then install all the software and drivers fresh. If you have not done that, you should, if you think you cannot at least uninstall the AJA software, FCP then reinstall FCP, do the upgrades then install the AJA software.
Most likely the IoHD firmware needs to be upgraded also.
If you are still have problems why not post all your settings.
Esteban Aguilar
on Mar 17, 2010 at 2:40:37 pm
Thank you very much: We will perform this procedure, To see if it.
