Kona LHi or Kona 3
Chris Arp
Kona LHi or Kona 3
on Feb 13, 2010 at 4:58:19 am
I am in retirement & work occasionally HVX-200a,FCP7,Matrox Mini Max & edit with final delivery 720P to blu-ray with toast 9. My question is, will kona 3 or Kona LHi put out a better signal capture card than FCP does for better quailty? I understand 8 bit & 10 bit. Plus I have read about cross conversion HD/SD! But does Kona help in quality other than that example to the picture itself. If it does a better job (Kona) which one would be best with the mentioned software. The blu-ray disc look great, but the FCP falls short in quality after I run it through Compressor for DVD deliverly.
Panasonic P2 HVX-200A
Matrox MXO-2 Mini "Max"
2.8 GHZ Mac Pro Quad Core
http://www.arpvideohd.com
chrisarp@mac.com
Chris Arp
Jeremy Garchow
Re: Kona LHi or Kona 3
on Feb 14, 2010 at 8:56:52 am
"put out a better signal capture card than FCP does for better quailty?"
Please explain...
Chris Arp
on Feb 14, 2010 at 4:27:22 pm
I looked up an article by Shane Ross that explained the benefits of the Kona 3 & understand the benefits better now! No need to reply! Thanks!
chrisarp@mac.com
Chris Arp
