Final Cut Pro video not getting to AJA ioHD
Dustin Parsons
on Feb 11, 2010 at 2:14:37 pm
I'm not sure where the problem is, I'm getting audio from Final Cut but no video. Please take a look at my settings:
Final Cut Settings: http://i49.tinypic.com/207xpb5.jpg
AJA ioHD Settings: http://i47.tinypic.com/2vt2uxv.jpg
Tried going from the AJA to monitor via composite and component cables, neither work.
If anyone has any suggestions that I should try it'd be greatly appreciated.
Jeremy Garchow
Re: Final Cut Pro video not getting to AJA ioHD
on Feb 11, 2010 at 7:51:11 pm
You have a lot of conflicts there.
Your sequence is set to 29.97 DVCPro HD (720P, 8bit)
Your video output is set to 720p 10bit ProRes.
Your Easy setup is set for 10bit ProRes SD.
Which do you need? What format is your footage?
Dustin Parsons
on Feb 13, 2010 at 1:19:01 am
Sorry for the delayed response. Turns out all I had to do is uninstall and reinstall the AJA software.
I layed off to tape 4 times with those settings without issue so... I don't know, it worked for me.
Thanks for the quick response.
Mac Pro | Leopard 10.5.5
2.66GHz Dual-Core Intel Xeon | 4GB Ram
Final Cut Pro Studio 2 | Avid Media Composer
