Original IO problems
Annaël Beauchemin
on Jan 17, 2010 at 9:52:09 pm
I'm trying to hookup an older IO to a 2ghz G5 running FCP 6.0.5 on 10.5.5.
The problem is that it displays only a still frame when I try to playback.
Before I investigate deeper, has anyone been able to run an IO on 10.5 and FCP 6?
Thanx!
Annaël
Jeremy Garchow
Re: Original IO problems
on Jan 19, 2010 at 12:28:25 am
Yes, but be sure to download the drivers and io control panel with firmware from aja.com/support
Michael Sacci
on Jan 19, 2010 at 4:37:40 am
[Annaël Beauchemin] "The problem is that it displays only a still frame when I try to playback. "
This is normally caused by having a mismatch of the video settings, the video out settings doesn't match the sequence settings.
Annaël Beauchemin
on Jan 26, 2010 at 4:56:40 am
thanx, that was it.
