ProRes422 with Big Endian
Preston Swigart
on Jan 12, 2010 at 11:55:00 pm
Hi
Have a request to take some PAL HDV footage and convert it to ProRes 422 HQ 1920X1080 Millions 16-bit Integer (Big Endian), Stereo 48,000 kHz. (copying this straight from the request--I think it is supposed to be 48khz, not 48000...)
Obviously the ProRes part can be accomplished with the IO, but if I'm not mistaken, the rest of the info refers to the audio codec and I was under the impression that the IO used "Little Endian". The audio is 48k in HDV so that part should be OK. Can anyone shed some light on this subject? Furthermore, does it even matter?
Thanks, Preston.
Jeremy Garchow
Re: ProRes422 with Big Endian
on Jan 13, 2010 at 10:42:31 pm
You should be fine. Send them a 2 second test to be sure.
