Final cut Pro setup for ioHD
Tony Brave
on Oct 30, 2009 at 4:48:56 pm
I have control setup for input svideo. The green light is on. everything look fine but when I open final cut it does not see video. I tried different capture setting: non-controllable, firewire NTSC but it doesn't bring up video. The thing about it is it used to work. What can I do I have a client waiting now.
Jeremy Garchow
Re: Final cut Pro setup for ioHD
on Oct 30, 2009 at 6:22:12 pm
Did you install the ioHD drivers? If so, you need to choose the proper easy setup.
Hit control-q and choose ioHD NTSC ProRes, or whatever format you need.
If not, you need to download and install the appropriate drivers for your machine at AJA.com
Jeremy
