ProRes = bad render with Slomo
Bill Portune
on Oct 24, 2009 at 5:20:36 pm
I have a sequence of shots in a ProRes timeline that are at 75% speed (or any speed change). When I render any transitions or title supers I get flashing at the bottom of the frame. It seems to include the last 5 or so lines and has a 4 frame cycle. I've tried dropping the same shots in various timelines (DV, DV50) and the problem is still there - seems it's associated with the source material not the timeline settings. I even re-digitized new source material with the same results. I was able to use a crop of 1 at the bottom of each shot which solved the problem.
Anyone else able to recreate the issue?
Using a MacPro 8 core, FCP 7.0.1, Snow Leopard, AJA iOHD 7.1
Bill Portune
Re: ProRes = bad render with Slomo
on Oct 24, 2009 at 6:23:44 pm
- 525 29.97 ProRes
- Was happening before I went to snow leopard with FCP 7.0
