AJA io / FCP issue
Rance Adams
AJA io / FCP issue
on Jul 9, 2009 at 3:14:29 pm
I've been editing with FCP and outputing video to a beta deck through an Aja io for a long time. All of a sudden whenever I try to print to tape, I get a message saying Pro Io Component RGB and Default audio may not match. Verify audio and video connects are externally routed to intended device. I never changed any settings, this mesage just showed up. Now I can digitize video and audio fine. I can output video fine, but the audio won't follow. Any thoughts or suggestions? I need help ASAP. thanx.
Producer / Editor
FCP 6
Aja Io
Jeremy Garchow
Re: AJA io / FCP issue
on Jul 9, 2009 at 3:41:42 pm
When mastering, make sure to select an easy setup that matches your timeline, then drag your sequence from the browser straight the to ETT window's 'Assemble' overlay.
Jeremy
