AJA IO and Nehalem?
Bob O'Hearn
AJA IO and Nehalem?
on Jun 20, 2009 at 10:49:51 am
I have been having difficulty with the audio breaking up and going out of sync on playback on my new 8 core "Nehalem" processor. I had AJA tech support step through the process with me and they had no explanation. After I hung up with AJA I connected to an older quad core mac it played perfectly. I have HDMI coming out to a Sony 1080p screen. I connected back to my new computer and the problem started again. Anyone have any idea what's going on? Thanks in advance. Bob
gary adcock
Re: AJA IO and Nehalem?
on Jun 20, 2009 at 11:07:24 am
Bob
I am assuming that you are using an IoHD?
so the audio is bad on the same content on 2 different machines?
what is the difference between the 2 computers.
Are you SURE that the firmware has been updated? (if not -do it again)
and post detail about your system and software.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Check out
http://www.aja.com/kiprotour/
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Bob O'Hearn
on Jun 20, 2009 at 11:49:33 am
Hi Gary,
Glad you're up early. Here are the specs of both computer.
Oldest first:
Model Name: Mac Pro
Model Identifier: MacPro2,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 3 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 8 MB
Memory: 8 GB
Bus Speed: 1.33 GHz
Boot ROM Version: MP21.007F.B06
SMC Version (system): 1.15f3
Serial Number (system): 1571618BUPZ
Model Name: Mac Pro
Model Identifier: MacPro4,1
Processor Speed: 2.26 GHz
L2 Cache (per core): 256 KB
L3 Cache (per processor): 8 MB
Memory: 12 GB
Processor Interconnect Speed: 5.86 GT/s
Boot ROM Version: MP41.0081.B03
SMC Version (system): 1.39f5
SMC Version (processor tray): 1.39f5
Serial Number (system): G891616420H
Serial Number (processor tray): J5911020V1LUC
I am using FCP 6.05. I think I am updating the firmware correctly. It just asked me to do it again but it looks like the firmware update I got previously. Could it be I am not updating correctly. I had to google "power cycle" to make sure I wasn't missing something.
Bob
Bob Zelin
on Jun 20, 2009 at 4:48:38 pm
uninstall, and reinstall your drivers.
Certainly, trash your FCP and AJA preferences.
Do you know how to do this ?
Bob Zelin
Bob O'Hearn
on Jun 20, 2009 at 7:04:32 pm
Bob,
I know how to trash my fcp preferences.Don't know how to trash and re-install AJA. I'd be grateful.
Bob
Bob Zelin
on Jun 20, 2009 at 9:32:56 pm
open up the AJA Utilities folder. There is an UNINSTALL in this folder. Run the uninstaller, and REBOOT your computer.
Then go to http://www.aja.com. Click on Support. Click on the AJA I/O HD to download the drivers for your I/O HD. Follow the instructions (which come on the screen when you start the installer). Reboot.
You should be fine.
If you are not, write back.
Bob Zelin
gary adcock
on Jun 21, 2009 at 1:19:43 pm
[Bob O'Hearn] "I know how to trash my fcp preferences.Don't know how to trash and re-install AJA. I'd be grateful."
BOB
hardware specs without the software specs are pretty useless. Like I said to understand the issue I need BOTH MACHINES OS versions, QT versions, Driver Versions, FCP versions
and don't just say they are all up-to-date give versions so WE know.
gary adcock
Studio37
Check out
Bob O'Hearn
on Jun 21, 2009 at 2:02:25 pm
Gary,
Both machines are running Leopard 10.5.7, Final Cut 6.0.5, AJA 6.0.3, the only difference is Quicktime.
The problem mac (Nehalem) is running 7.6.2 and the older mac is running 7.6. Let me know if I left something out.
Bob
gary adcock
on Jun 21, 2009 at 3:15:30 pm
[Bob O'Hearn] "The problem mac (Nehalem) is running 7.6.2 and the older mac is running 7.6. Let me know if I left something out. "
ATI or Nvidia card in the problem machine.
and yes the 2 versions of QT could be at issue, if you have the nvidia card in the problem machine.
gary adcock
Studio37
Check out
Bob O'Hearn
on Jun 21, 2009 at 3:29:07 pm
I have a Nvidia Ge force GT 120 in the problem machine and ATI Radeo X1900 XT on the one that's running smoothly. Do you think AJA will provide an update if that's the case?
gary adcock
on Jun 21, 2009 at 10:03:58 pm
[Bob O'Hearn] "Nvidia Ge force GT 120 in the problem machine and ATI Radeo X1900 XT on the one that's running smoothly. Do you think AJA will provide an update if that's the case?"
Why would they?
this is not the first time I have heard of a playback issue on that machine/nvidia combo, but does not appear to me to be an 3rd party problem, it is more like (educated guess) to do with new GPU processing code at the Core OS level conflicting with older CPU processing code in the applications.
gary adcock
Studio37
Check out
Bob O'Hearn
on Jun 21, 2009 at 10:24:25 pm
Gary,
Thanks for all your help.
Bob
Jeremy Garchow
on Jun 22, 2009 at 3:49:31 pm
What are you using for scartch drives and what format is your footage and timeline?
Jeremy
Bob O'Hearn
on Jun 23, 2009 at 4:42:03 pm
Hi Jeremy,
For my scratch drive I am using a 750 gb internal hard drive and the format on the timeline and footage is pro res 422.
Bob
Jeremy Garchow
on Jun 23, 2009 at 4:32:54 pm
[Bob O'Hearn] "For my scratch drive I am using a 750 gb internal hard drive and the format on the timeline and footage is pro res 422. "
1080i? That might not be a fast enough drive even the specs might tell you so. Whenever anything goes out of sync on playback, it's usually due to slow drives.
Jim Wiseman
on Jun 24, 2009 at 9:16:43 am
FCP 6.0.6 update may fix your problem. Available now.
http://support.apple.com/downloads/Final_Cut_Pro_6_0_6
Jim Wiseman
Bob O'Hearn
on Jun 24, 2009 at 8:20:38 pm
Jim,
That did it! Everything plays great. Thanks very much. Thanks to everyone for all your help.
Bob
