AJA IO HD - "device offline" in control panel - help
David Reppond
on Apr 19, 2009 at 7:34:24 pm
Hi Everyone - My AJA IO HD unit is coming up as "device offline" in the control panel.....not sure what's happening because i downloaded recent version 6.0.3
any help would be really appreciated. i'm under a deadline and this thing is driving me crazy :)
Carsten Orlt
Re: AJA IO HD - "device offline" in control panel - help
on Apr 20, 2009 at 5:07:26 am
I never had that problem so the following is just a thought..
Can it be that the ioHD wasn't connected at the time you updated the drivers?
Maybe, with the ioHD connected, try re-installing the software again and make sure the io updater finishes burning the software to the ioHD as well!
If you done all that already The only other thing I could think of is a faulty cable, a faulty ioHD, other devices on the firewire bus...
You might have to cal Aja.
Carsten
Jeff Mack
on Apr 20, 2009 at 3:28:01 pm
Try turning off and then back on.
Jeff
Jeremy Garchow
on Apr 26, 2009 at 12:36:02 am
Restart?
Jeff Mack
on Apr 26, 2009 at 12:39:27 am
This has happened when I connect out of order. I turn off the IOHD (switch on the back) and it comes online.
Jeff
Kent Stipp
on Apr 27, 2009 at 8:08:10 pm
I know that some people have had an issue with the latest drivers and needed to go back one rev. The only other thing I can think of is make sure the IoHD is powered on before restarting the computer
Kent Stipp
Life Begins at 155mph
Ki PRO Lens to Post
3am Studios llc.
3amstudios.org
Sharedsummitsfever.com
