Crosspost: Export QTs with Time Code from FCP
Juanjo Mora
on Apr 12, 2009 at 10:09:46 pm
Hi to every one!
I'm capturing dailies from a telecine directly to Final Cut Pro, using an AJA ioHD. The capture is being done at 1080psf@23.98fps.
From there I need to send to the editor QuickTime files in DV codec, 720x480 letterbox @23.98fps.
The problem is that when I export my clips using QuickTime Conversion they don't have Time Code.
How can I do this?
Regards,
Jj
MacPro 3,1
2x Quad-Core Intel Xeon@2.8GHz
4GB RAM
4x 1TB HDDs
MacOS 10.5.6
FCS 2
Adobe CS4 Production Bundle
Michael Sacci
Re: Crosspost: Export QTs with Time Code from FCP
on Apr 13, 2009 at 8:24:33 am
It would be best if you just posted in one forum. This is a FCP question (and saw you posted there) not a IoHD.
Not being mean this is just proper etiquette.
Juanjo Mora
on Apr 13, 2009 at 1:46:25 pm
Dear Michael,
Accept my apologies.
Just a little desperate because of the deadlines and thought maybe I could get an alternative workaround (inherent to the ioHD)by crossposting to this forum.
Never was my intention to offend or bother anyone.
Regards,
Jj
MacPro 3,1
4GB RAM
4x 1TB HDDs
MacOS 10.5.6
FCS 2
