Time Code window burn in ioHD
Ron Frank
on Apr 11, 2009 at 2:40:08 am
I'm trying to do a time code window burn from my MacBookPro thru the ioHD. I must be missing something because the manual says you can do time code window burns, yet I don't see a time code window burn box like I used to have with the Kona3 software.
To those of you who have worked with the ioHD, is it possible to play video through the ioHD box and have a time code window visible on the outputs? The time code is correctly displayed on the box's front panel but I can't get the outputs to display the time code the way the Kona3 does.
Help!
Ron Frank
gary adcock
Re: Time Code window burn in ioHD
on Apr 11, 2009 at 1:35:54 pm
[Ron Frank] "To those of you who have worked with the ioHD, is it possible to play video through the ioHD box and have a time code window visible on the outputs?"
Sorry Ron
there is not a timecode burn-in from the IoHD like there is on the Kona cards.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Ron Frank
on Apr 13, 2009 at 1:50:55 pm
Thanks for the info.
Ron
