FCP not seeing VITC timecode...
Juanjo Mora
on Apr 9, 2009 at 5:31:44 pm
Hi to everyone!
As you can see I'm an io HD newbie...
Let me explain what I'm doing:
I'm capturing dailies for a 35mm 3-perf feature film.
In 1080@23.98psf: from a Shadow Telecine to Aaton Keycode to HDCAM VTR to AJA ioHD vía SDI-HD. House Sync is tri-level 23.98 psf. There is no control cable (9-pin RS-422) between the HDCAM and the AJA io HD: we are using it 'wild'.
We want to capture in one pass simultaneously from the Shadow to both the HDCAM and Final Cut.
We have everything working now EXCEPT for the TC into FCP... in the AJA io HD display I have the VITC1 time code that matches perfectly the time code from both the Aaton and the HDCAM...
But when I capture in FCP and check the clip's time code it is zeroes...
I guess FCP gets its Time Code input from the LTC or the RS-422 ports of the io HD, right?
Is there a way for capturing the VITC time code in FCP?
Regards,
Jj
MacPro 3,1
2x Quad-Core Intel Xeon@2.8GHz
4GB RAM
4x 1TB HDDs
MacOS 10.5.6
FCS 2
Adobe CS4 Production Bundle
gary adcock
Re: FCP not seeing VITC timecode...
on Apr 9, 2009 at 5:59:22 pm
[Juanjo Mora] "Is there a way for capturing the VITC time code in FCP?
Use VTR EXchange ( Its available on the software downloads page.
FCP can only see timecode over a 9 pin RS422 serial connection.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Juanjo Mora
on Apr 9, 2009 at 6:12:13 pm
Thank you!
Excellent.
Jj
MacPro 3,1
4GB RAM
4x 1TB HDDs
MacOS 10.5.6
FCS 2
