Can AJA io HD capture at 24psf?
Juanjo Mora
on Apr 9, 2009 at 1:47:24 am
Just received our new AJA io HD and with great surprise noticed that it seems to not be able to capture at 24p segmented frame from our HDCAM deck.
Is this true?
Please help.
Regards,
Jj
Media 100 XR v8.2
G4 dual 1.25, 2GB RAM
MacOS 10.2.8
Dual Monitor, Wacom Tablet
144 GB SCSI-160 RAID, ATTO UL4D
240 GB ATA Internal
1.5 TB External Firewire 800
Gustavo Mendes
Re: Can AJA io HD capture at 24psf?
on Apr 9, 2009 at 9:12:12 am
Yes,it can.just choose the easy setup for it.Make sure you have the newest drivers installed.
Always learning....
gary adcock
on Apr 9, 2009 at 1:47:52 pm
[Juanjo Mora] "Just received our new AJA io HD and with great surprise noticed that it seems to not be able to capture at 24p segmented frame from our HDCAM deck.
Is this true?
it works just fine, I have been 1080 23.98 sf without issue since the beginning.
Since you did not say what is your issue?
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Jeremy Garchow
on Apr 9, 2009 at 2:08:33 pm
The ioHD needs an intel processor for it to work. It will work on a G5 Quad, but definitely not on a G4.
Juanjo Mora
on Apr 9, 2009 at 2:23:07 pm
Hi Gary!
My issue is that it doesn't seem to capture at exactly 24 progressive segmented frame... not 23.98
Regards,
Jj
gary adcock
on Apr 9, 2009 at 2:39:44 pm
[Juanjo Mora] "My issue is that it doesn't seem to capture at exactly 24 progressive segmented frame... not 23.98 "
Ok
24p is considered 23.98 (why do you think you need to do 24.0?)
You will need to load those specific settings settings during the driver install- they are not part of the base install.
Secondly you equipment details listed ARE NOT COMPATIBLE with the IoHD
this hardware device requires OSX 10.411 or later and fcp 6.0 or later and nothing else on the FW bus.
gary adcock
Studio37
Juanjo Mora
on Apr 9, 2009 at 3:22:19 pm
Hi to everyone!
I'm very grateful for your answers and feedback.
Sorry about my old signature, here are the details for my equipment:
MacPro
2 x 2.8GHz Quad-Core Intel Xeon
4GB RAM
4 x 1TB HDDs
OS 10.5.6
Now, in stand alone mode I get the ioHD to input 24psf without problems, the reason I need exactly 24psf is that this system is integrated into a larger facility and the material we work here with comes from an HDCAM deck that is set to record and playback at 24psf, the house tri-level-sync is also 24psf...
Using the AJA ioHD Control Panel I have no trouble at all 'inputing' a 24psf signal into the ioHD.
It's in FCP 6 where I have trouble: there is no preset for 1080@24psf, only to 23.98psf and when I input the HDCAM signal in that setting it just gets digital 'garbage'...
The facility video engineer refuses to put the machine into 23.98psf mode (I know the machine can do that) and insists in working at 24psf...
Right now I'm downloading the latest drivers for AJA ioHD and the latest updates for FCP...
Will reinstall and look for specific settings for 24psf.
Meanwhile any ideas?
Sorry for the long post! And again thank you vey much guys: I'm very grateful for all yur feedback and your fast answers.
Regards,
Jj
gary adcock
on Apr 9, 2009 at 5:11:49 pm
[Juanjo Mora] "It's in FCP 6 where I have trouble: there is no preset for 1080@24psf, only to 23.98psf and when I input the HDCAM signal in that setting it just gets digital 'garbage'... "
What part of you need to reinstall the driver to get 24.0 playback and setups for FCP did you miss.
24.0 IS NOT PART of the base install for the unit do to the rarity of use in most workflows.
gary adcock
Studio37
Juanjo Mora
on Apr 9, 2009 at 5:18:51 pm
Thanks to everyone!
Talked with AJA support and what I want to do is just not possible, but found a workaround.
Regards,
Jj
MacPro 3,1
2x Quad-Core Intel Xeon@2.8GHz
4GB RAM
4x 1TB HDDs
MacOS 10.5.6
FCS 2
Adobe CS4 Production Bundle
Michael Sacci
on Apr 9, 2009 at 7:07:46 pm
[Juanjo Mora] "The facility video engineer refuses to put the machine into 23.98psf mode (I know the machine can do that) and insists in working at 24psf... "
Okay I'm curious, these are genuine questions, why would anyone want to have the deck set like this? What would be the benefit of it? Would it not cause all sorts of problems for everyone down the road?
gary adcock
on Apr 9, 2009 at 7:37:53 pm
[Michael Sacci] "Okay I'm curious, these are genuine questions, why would anyone want to have the deck set like this? What would be the benefit of it? Would it not cause all sorts of problems for everyone down the road? "
Good Question Michael.
the 24.0 workflow has become increasingly rare- mainly due to one reason- it is impossible to monitor in SD in realtime ( SD is 29.97 and it would require a delay inaddition to adding pulldown to make it work)
24.0 is still common in scientific and speciality ( NASA works in round numbers to allow for easier sync with film captures.
In the HD realm it is fairly uncommon.
gary adcock
Studio37
Michael Sacci
on Apr 9, 2009 at 7:47:53 pm
Understood about Film out, didn't think of the other, thanks.
[gary adcock] "24.0 is still common in scientific and speciality"
Scientist, they will kill us all one day!
Juanjo Mora
on Apr 9, 2009 at 7:58:19 pm
Hi!
Up to this day we had worked in an exact 24p workflow for all of our previous featre films involvements.
Usually we worked all the time with propietary equipment and software in HD with all the deliverables in HD and on-line editing in Avid.
And yes, we finish in film out.
This project is our first in many aspects:
a) It's our first long-form feature film with 35mm 3-perf (and 4-perf for VFX)
b) It's our first for making deliverables at SD (NTSC)
c) It's our first with an editor using FCP
So we are starting to 'adapt' to the rest of the world.
Regards,
Jj
MacPro 3,1
4GB RAM
4x 1TB HDDs
MacOS 10.5.6
FCS 2
