IoHD PAL Ingest to FCP
Bruce Rawlings
on Feb 22, 2009 at 7:36:31 pm
I have been using the IoHD unit to playout PAL DV projects to Digibeta in SDI from a MacBookPro. I inherited the FCP project and a hard drive with the media on it. All has worked well.
I now want to start a new SD project that will bring in Digibeta pictures. I have set up FCP project in easy set up 625 and used the IoHD panel to set up 625 - blue workflow throughout. When I actually digitise from a Sony J3 deck the IoHD decides that the project is 72050p! What am I doing wrong?
Jeremy Garchow
Re: IoHD PAL Ingest to FCP
on Feb 22, 2009 at 7:50:53 pm
Are you using the FCP easy setups?
HIt control-q and choose AJA ioHD 625i and the appropriate codec.
