capture 720p25 proress HQ on macbook pro okt 2008 unibody?
Martijn Scholte
on Jan 27, 2009 at 1:35:53 am
hi all
is this possible? on my standart 5400 rpm internal disk?
i also remember that when hooked up to my ex1 the oi hd states that a 50p signal is present? i would like to capture only 25 fps? i dont rember is this is possible?
cheers
Martijn
The box said 'Requires Windows 95, or better.' So I bought a Macintosh.
Jeremy Garchow
Re: capture 720p25 proress HQ on macbook pro okt 2008 unibody?
on Jan 27, 2009 at 2:04:58 am
[Martijn Scholte] "is this possible? on my standart 5400 rpm internal disk? "
It's not recommended. At the very very least, you should get a 2 drive fw800 array with a fw Express/34 card.
Even better would be a 2 drive SATA array with a SATA Express/34 card.
As far as 720p25 vs 720p50. What the source of your incoming video?
Martijn Scholte
on Jan 27, 2009 at 7:35:34 am
an sony ex1 hd-sdi out
not recommended or not possible?
cheers
gary adcock
on Jan 27, 2009 at 5:21:57 pm
[Martijn Scholte] "an sony ex1 hd-sdi out
not recommended or not possible? "
The HDSDI stream is always playing at 50p, however since you are using the HDSDI feed into an IoHD use the same technique that is used for Panasonic cameras in the IoHD article listed below to extra 25p from that camera.
Sony was smart enough to include the PR188 frame flagging systems that is currently in use and in 720p it works the same as Panasonic camera's do.
Listen to the other posts - DO NOT record video to your system drive.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Jeremy Garchow
on Jan 27, 2009 at 5:31:04 pm
[Martijn Scholte] "not recommended or not possible? "
I couldn't possibly recommend it.
As Gary says, the EX1 does send variable frame rate info to the ioHD. If using VTR Exchange, use the 1280x720 10 bit 720p50 VFR setup and set your frame rate to 25, and codec to ProRes or ProResHQ. Make sure your camera is setup for the same (720p25).
Jeremy
