No colour capturing S-Video
Stephan Laeuppi
on Dec 12, 2008 at 2:02:53 pm
Hello everbody!
I finally mangaged to install my new AJA io. I am using it in order to digitize analog PAL video material with Final Cut Pro (5.0.1) on a G5 running on OSX .
Capturing BetaSP Material via Component (YPbPr) works fine.
Capturing VHS via Composite Video works fine.
Capturing S-VHS Video via the SVHS In connection delivers a black and whithe image only. Somehow the Chroma information does not get through. What could be the error?
Many thanks for your help.
Stephan
todd reid
Re: No colour capturing S-Video
on Dec 12, 2008 at 3:29:05 pm
have you checked all the "prongs" on the svideo cable (male)? Those things are very delicate, and I have bent, then broke a few in my day.
Try another svideo cable. If everything else is working, I bet its your cable.
Todd Reid
Senior Editor
Digitized Media, Inc.
Jeremy Garchow
on Dec 12, 2008 at 5:11:41 pm
[todd reid] "If everything else is working, I bet its your cable."
Me too!
Stephan Laeuppi
on Dec 13, 2008 at 1:45:37 pm
Thanks for your replies!
It cannot be the S-Video cable, since going directly to the Sony Video monitor from the S-VHS player with the same cable I get the colour information. The chroma channel gets somehow lost, when I go into the AJA io.
I tried it using Final Cut and its settings as well as with the Control Panel - no colour on the S-Video.
Somehow strange that in the control panel I can chose in the Input Menue "S-Video" but only have the choice between Component Output options...
Jeremy Garchow
on Dec 13, 2008 at 7:05:53 pm
Is this an io or an ioHD?
Stephan Laeuppi
on Dec 15, 2008 at 8:15:14 am
It is an AJA io.
Jeremy Garchow
on Dec 15, 2008 at 6:27:05 pm
If you set the AJA control panel is input passthrough, can you get a color image out of the AJA output? (bypass FCP for now).
Jeremy
Stephan Laeuppi
on Dec 16, 2008 at 2:32:12 pm
Hello Jeremy
Yes I do get a colour image on the AJA-output using composit or component signals. It is only with the S-Video signal that I lose the colour. I checked the S-Video cable (putting it directly to the monitor). The colour is there. As soon as I go into the AJA I only get a black and white image. Do you think the S-Video in socket of the AJA may be damaged?
todd reid
on Dec 16, 2008 at 3:46:31 pm
have you spoken with AJA?
You may need a replacement box.
You are obviously experiencing something that is not the norm.
Call them and take advantage of your warranty.
Todd Reid
Senior Editor
Ernie Santella
on Dec 23, 2008 at 6:16:06 am
I also get the B&W issue when I try to digitize from a DVD player through the S-Video in. Try switching to Composite and then back to S-Vid, that usually clears it up for me. Not sure why.
Ernie Santella
Santella Productions Inc.
http://www.santellaproductions.com
Stephan Laeuppi
on Dec 23, 2008 at 8:50:53 am
Hello Todd
Thanks for your message. In the meantime I contacted AJA and told them about the SVideo problem. The response to my email came the very same day.
Within 4 days I had a replacement box sent from California to Switzerland. I have to say I am really impressed with the Customer Support of AJA! Thumbs up!!!
todd reid
on Dec 23, 2008 at 2:44:47 pm
I love it when a plan comes together!
That is one of the things I like about AJA. I've always had great experiences with their customer support.
I assume that the new one is working like aces!!!!
Todd Reid
Senior Editor
