AJA io V.S. Black Magic Design Multi Bridge Eclipse
Micah Wolf
on Dec 4, 2008 at 5:03:14 pm
Can any one tell me the + and - between the AJA io over Black Magic Multi Bridge Eclipse.
I will be running Adobe CS3 on Leapord.
Any info would be great.
Thank You
Micah
Carsten Orlt
Re: AJA io V.S. Black Magic Design Multi Bridge Eclipse
on Dec 4, 2008 at 8:15:37 pm
If you would make the effort to check the system requirements on the Aja website you would see that the Aja IO range is Final Cut only . . .
Carsten
Micah Wolf
on Dec 4, 2008 at 8:23:03 pm
But it does work with After Effects which is an adobe product. So will it work with Premier Pro as well and for the record I have but in effort in looking into these two products no reason to be short Carsten
Carsten Orlt
on Dec 4, 2008 at 9:35:23 pm
io doesn't work with Premiere Pro.
and yes sorry for being short. :-)
Micah Wolf
on Dec 4, 2008 at 9:49:22 pm
Thank you
gary adcock
on Dec 5, 2008 at 2:08:18 pm
[Micah Wolf] "So will it work with Premier Pro as well and for the record I have but in effort in looking into these two products no reason to be short Carsten"
nope
sorry but it will not work with Premier...
carsten is correct.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Matty Causon
on Dec 6, 2008 at 12:24:22 am
Hello Micah
Whilst the AJA Io range are FCP based product, the AJA Kona cards (Mac) and Xena cards (PC) both work with Adobe Premier so you perhaps should consider compare those with the MultiBridge?
What's more you could say the Kona/Xena range are more comparable to the MultiBridge as they are also PCI/PCIe based cards designed for working with Desktop computer.
The Io range are designed principally to work with Laptop computers (Mac). The Multibridge does not.
If you do some searches you should find many strings regarding the many pros and pros of using Kona/Xena product over the Multibridge. But if you need some assistance let us know.
Best regards
Matthew Causon
AMP Europe
