Setup of Aja IO with FCP
Kaspar Schroder
on Nov 21, 2008 at 3:15:28 pm
I hope someone can help me with this totally newbie question.
I've borrowed a AJA IO, to view my grading on an external monitor. I've installed the software and connected through FW800. I can see it's receiving the audio and assume the video is there as well. Now I just don't know how to get the image through to the monitor.
I've enabled ALL FRAMES ON in VIEW. What should I choose in Video playback (my sequence/material is 1080i-50 PAL HDV) and how should I hook up the AJA IO to the monitor, which is a JVC TM-H1950C? It's got BNC and S-Video input, but I stink at connecting machines. Am usually just editing and someone assists me with the gear.
Hope someone has the goodwill to help :-D
Jeremy Garchow
Re: Setup of Aja IO with FCP
on Nov 21, 2008 at 4:51:06 pm
Hit conrol-q and choose the easy setup that matches your footage.
Jeremy
Kaspar Schroder
on Nov 21, 2008 at 4:54:34 pm
Thanks. Which one will match HDV? And how should I connect the AJA to the monitor?
Tnx
Jeremy Garchow
on Nov 21, 2008 at 5:25:48 pm
With HDV, you need to set your timeline to render in ProRes in the sequence settings, then select the easy setup that matches your footage/frame rate (1080i25, ProRes). You can't play out HDV in real time until you render to ProRes with the ioHD.
[Kaspar Schroder] "And how should I connect the AJA to the monitor? "
What kind of monitor? What connections does it have? Is it an Hd monitor?
Kaspar Schroder
on Nov 21, 2008 at 5:30:55 pm
No, it's an SD monitor from JVC. It has 2 BNC in/out and one S-video in/out...
Jeremy Garchow
on Nov 21, 2008 at 6:57:39 pm
Take an Svideo cable and connect the output of the ioHD to the input of the tv.
Kaspar Schroder
on Nov 22, 2008 at 3:17:03 am
Thanks.
What output should I choose in FCP for HDV?
