puple image from betcam
Core van der Hoeven
on Oct 30, 2008 at 12:21:13 pm
Hello
Probebly something simple, I'm a novice with betacam
I'm trying to capture from a betacam deck with my AJA io HD
I get an image, but it is very purple
is there someone out there who can give me some advice
Core
Mark Beazley
Re: puple image from betcam
on Oct 30, 2008 at 2:58:21 pm
Make sure your component input is switched over to YUV and is set to Betacam levels (as opposed to SMPTE). Click on the component input on the control panel and it should let you change away.
-mark
Core van der Hoeven
on Oct 30, 2008 at 3:48:30 pm
thanks for your reply,
The component input is set to component beta
It's the only other option I have with component
Core
Jeremy Garchow
on Oct 30, 2008 at 4:38:33 pm
Is your monitor set to RGB instead of Component?
Jeremy
Core van der Hoeven
on Oct 30, 2008 at 4:43:10 pm
no, it's set to component
Is there maybe a setting on the betacam deck wich could be the course
Core
Bob Zelin
on Oct 31, 2008 at 2:04:52 am
can you use these same cables to plug your Beta component signal directly into the component input of your TV monitor ? This will tell us if you have a problem with your Beta VTR or TV monitor (or cables).
ALSO, go to the I/O HD Control Panel, click the CONTROL tab, and select TEST PATTERN, color bars -
do you see good color bars, or do they look purple ?
Bob Zelin
Core van der Hoeven
on Oct 31, 2008 at 8:31:30 am
That's an idea, I'll check that right away, maybe the
cable's are not doing what they supposed to do
My client monitor works ok and I have good color bars
It's the color bars from the tape that are purple(and
the images)
Core
Mark Beazley
on Oct 31, 2008 at 1:25:28 pm
The Beta input might be set to RGB instead of YUV, what is the model of Beta deck you are using?
-mark
