Why No Output via AJA IO?
Brad Froman
on Oct 16, 2008 at 7:55:30 pm
A few months back, I had to re-install FCP 5.0.
After the FCP install, I had to download the AJA IO v2.1 packages of preset settings (ie. Analog NTSC_US.pkg).
I have no output via AJA Io.
Now, when I start a session by going to "Easy Setup" and choose "AJA Io - NTSC US Betacam 10bit 23.98 Uncompressed", I am able to digitize the material into FCP through AJA Io, but, there isn't any output. I see/hear playback within FCP on the desktop.
The audio/video settings show "Pro AJA Io" in the audio and video output settings.
Does anyone have any ideas where I'm going wrong?
Thanks.
Jeremy Garchow
Re: Why No Output via AJA IO?
on Oct 16, 2008 at 8:55:07 pm
Change your video output to 29.97
Brad Froman
Still Having Problems
on Oct 16, 2008 at 9:13:33 pm
Sorry...I meant to say I chose Easy Setup for "AJA Io - NTSC US Betacam 10 Bit Uncompressed. The timeline setting is 29.97. So, again, after creating a new Project, I digitize a sample clip (which looks and sounds fine importing through AJA), when I try to play the clip back, the AJA does not allow me to see/hear the clip.
Audio/Video settings are as follows:
Sequence Preset: Uncompressed 10-bit NTSC 48 kHz
Capture Preset: AJA Io: YPbPr Betacam 10-bit NTSC US 48 kHz
Device Control: AJA Io RS-422 NTSC
Video Playback: ProIo - NTSC US - Component YPbPr Betacam 525 - 10-bit (720x486)
Audio Playback: ProIo Out
Jeremy Garchow
Re: Still Having Problems
on Oct 16, 2008 at 9:19:57 pm
Go to your View > External Video menu and make sure it's set to All frames and that audio follows video in the audio playback menu.
Jeremy
Brad Froman
on Oct 16, 2008 at 9:29:00 pm
External Video was "Off", but I switched to "All Frames"...and still nothing. Audio is following video.
Jeremy Garchow
on Oct 16, 2008 at 9:34:04 pm
Okay, now hit option-f12 to refresh devices.
Brad Froman
on Oct 16, 2008 at 9:45:54 pm
I will do. Thanks again!
Brad Froman
Got It!
on Oct 16, 2008 at 9:32:16 pm
I stand corrected...you were right. Someone had switched the monitor input without my knowledge...so I wasn't seeing the change you suggested.
Thank you so much! I'm back in business!
Gotta love the Cow and nice folks like you.
Jeremy Garchow
Re: Got It!
on Oct 16, 2008 at 9:35:16 pm
Glad you're up and running!
Jeremy
